Old 12-17-2013, 08:17 PM   #10 (permalink)
sully06
Camry - '99 Toyota Camry
90 day: 39.84 mpg (US)
Originally Posted by mcrews View Post
Remember, only 1/2 of the 1.6 inches is on the top of the tire. So I cant imagine clearance would be a problem.
also,You need at least a 5% larger diameter to show real mpg improvement.
need to be looking at the 215/70/15. that is just over 5% of the stock 15 inch tire.
215/70R15
98T SL
Max Load = 1,653 lbs
Max psi = 44 psi
680 A B 1653 lbs.
44 psi
11.5/32"
24 lbs. 5.5-7"
6.5"
8.7"
7.2"
26.9" (25.5 diameter for stock 15 " tire)
774
Might that be too wide and cancel out my fuel savings?
99 Camry
