So far, the fixes to the Metro are getting done, but slowly. Just bought an oil pan as the one on there is bent and slightly crushed on the front. The leak is next to the flywheel, which the flywheel slings the oil onto the catalytic converter sending plumes of smoke out the back side. New oil pan will definitely fix that. Got to find an inspection plate to put on there to keep the flywheel covered from debris.
After the oil pan gets fixed, I'll be purchasing exhaust valves and intake valves from 3Tech over on TeamSwift, saving up for all the gaskets, piston rings, Eco/Perf cam grind, and send the/a head off to get the machine work done.
'93 MX-3 Base B6: Cat-back
'12 Elantra GLS 6 Speed: S.O.'s DD
'92 MX-3 GS: KL-ZE swap: S.O.'s WW
'91 Dakota V6 5 Speed 4x4: Parked for Summer
