Unicorn products? Wetter than wet, Litebrake, Alcohol Water injection?
Okay
I was not sure where to post this and was going try here.
I am curious about the following topics
because the claims about increase mpg
Coolant Additive .....................Wetter Wet product sold Autozone Yes/No/No Diff?
Litebrake............................... alum clad rotor disc (pricy) Yes/No/ Any1 tried
AWK...................................alcohol water injection kits. aem/cooling mist some sold on
ebay. This concept has been around for a while during the 1970s fuel crisis .. ... also some do the DIY with some current cars. When I say water this is a term found previous really more of a liquid mix which some use variety liquids which is then either pump pressure indirectly into airintake or through evap. The following solution have also been done in the past water/alcohol/and sometime soap bubbles.................
... I am unsure about this on modern vehicle just like the claims with HHO just not found to be in the realm of do able or pratical..........
