Thread: Diamond Lube
Old 12-19-2013, 05:38 AM   #41 (permalink)
RustyLugNut
Thank you.
Originally Posted by DIMS View Post
It seems this could be tested on an air cooled lawn mower engine. I think it would easy to test.
1: Before & after torque required to turn motor with & without plug.
2: Measure idle Rpm before & after
3: measure Oil temp before & after
4: measure head temperature before & after
Just an idea to throw out there.
I was thinking along the same lines. However, the sample size of just a few cc's may not be effective in a simple bath addition. It may take a bit of doing to burnish the material into the cylinder walls and bearing surfaces.
Another solution is to get the raw material from a manufacturer. A kilogram can be purchased for 100 dollars US in various grades. This however would not be a test of DiamondLube products but a generic test of nano diamonds.
