Thread: C-Max diffuser
Old 12-21-2013, 05:52 PM   #1 (permalink)
Recumpence
My C-Max - '13 Ford C-Max SEL
C-Max diffuser
Hey Guys,
First let me say a quick "Thank You" to all of you for puting up with all my newbie questions. I appreciate all the input I have received from all of you.
OK, warm fuzzies aside, I have begun the somewhat daunting task of building the diffuser for my C-Max.
This is a difficult task for a number of reasons;
#1 There are precious few areas to mount anything to under the rear of this car.
#2 The exhaust system needed to be lifted 2 inches to provide a proper curve and angle of the diffuser.
#3 I needed to make a subframe for the diffuser because (as I mentioned before) there are almost zero places to attach panels to under the car.
So, you can see that I moved the exhaust up 2 inches. Then I TIG welded together a 3/4 inch 14 gauge 6061 aluminum frame to which I pop riveted 4mm thick G10 panels to form the rear 14 inches of the flat section as well as the vertical fins. Then I used 4mm thick black Coroplast for the forward section of the diffuser.
What you see here is 37 inches long and 22 inches wide. The remaining areas to each side of this center section are roughly 16 inches per side. These side portions will be shaped a little different from the center and will be built as separate parts, bolted to each side of this center section.
I have 7 hours of time into this project total so far. The aluminum frame is very light as is the Coroplast. The G10 is a bit heavy, though. That (and cost reasons) is why I only used G10 for portions of the diffuser, but not the entire thing.
Oh, lastly, I will probably reduce the height of the vertical fins of the diffuser to make it look a bit better.
Being that this thing is only partially done, the results will be minimal until I have it finished. That being said, I have noticed the rear window is vastly cleaner than before. This car has had the worst rear window airflow I have ever owned. I go through a huge amount of washer fluid trying to keep the window clean and, so far, the rear window is drastically cleaner than before I installed the diffuser.
With Christmas here, odds are the remaining portion of the diffuser will take a couple weeks to finish.
Matt
ID:	14271   Click image for larger version
ID:	14272   Click image for larger version
ID:	14273   Click image for larger version
ID:	14274   Click image for larger version
ID:	14276   Click image for larger version
ID:	14277   Click image for larger version
ID:	14278   Click image for larger version
The Following 9 Users Say Thank You to Recumpence For This Useful Post:
BamZipPow (12-22-2013), California98Civic (12-22-2013), Cd (12-28-2013), Cobb (12-21-2013), Eastwood (05-11-2014), jeff88 (12-21-2013), mcrews (12-25-2013), renault_megane_dci (12-28-2013), wdb (12-22-2013)
