Old 07-02-2008, 03:39 PM   #6 (permalink)
millenniumtree
Polymer - '89 Honda Civic Hatch Std 4 speed
Woodstock - '69 MG Midget 1275
Nekobus - '06 Scion xB
My car has no power steering, and braking force is only marginally decreased once I run out of vacuum.
If I do happen to lose vacuum (after 3 _FULL_ depressions of the pedal!!), I still have plenty of braking ability, in addition to a very good parking brake.
I need the engine on so often anyway that I realistically never run out of booster vacuum. It's all little hills around here and I need to restart every time I go up one. EOCing down the rocky mountains, I could see as dangerous and I would never do that. (You'd need to engine brake anyway!) Besides, that's what DWBing is for. You shouldn't have to touch your brakes - if you do, you're emergency stopping anyway, and your booster will hold out for that unless you have a catastrophic vacuum leak, in which case you shouldn't be driving it anyway!
I NEVER do more than 5 over.
I rarely fall more than 5 under unless there is no one behind me for as far as I can see or it's a slow (35 or less) road with two full lanes.
All the above said, if people are tailgating or overtaking me, I will get the hell out of their way or drive "normal" to appease their sense of urgency without risking my life.
If I do any drafting at all, it's at least 5 car lengths back. Kissing a trailer's bumper for an extra 2mpg just isn't worth it!
One of my other cars is downright crippled without the engine on. The steering effort goes up a lot, and you just can't stop properly once the booster runs out. (You could use the parking brake though) Which is more dangerous, a car in which everything still works fine with the engine off, or one that turns into a railroad car??
Modern technology be damned.
I've gotten 3 speeding tickets (before hypermiling), and had a car totaled by a sun-blinded driver who went right through a red light. If you can't see the light, just assume it's green!!??!!
