So far so good.
Of course, this is only about 40% of the entire diffuser. However, the last bit will be far quicker to build because I already have the foundation made. ABA testing should be really easy because this is designed to be easy to install and remove.
It is strange how clean my rear window is with this thing. I am sure it will be even better with the entire diffuser done.
Oh, my coasting is noticeably better. Also, when the engine kicks on, I cannot see any exhaust behind the car anymore. Normally my rear window is swirling with exhaust.
I will keep you guys posted.
Matt
