Old 12-24-2013, 01:05 PM   #6 (permalink)
Cobb
Yeah, it only takes 3-4 hours to fully charge the pack, even at 350 ma. The balancing process takes much longer at that same amperage.
Ive tried to keep up with the latest developments in grid charging and pack reconditioning, but a lot of it is conflicting. Last I read you shouldnt discharge below a certain point, then you should as it helps to restore.
I dont do either fuse or battery disconnect method, seems the 2nd gen is more able to see the pack status and after a fresh charge it runs it down then does a negative recalb to get it right or up to 80%.
