Originally Posted by RedDevil
Doessn't anybody have the notion that if regular is good and E10 is bad, it might just not be the ethanol which is to blame but the poor quality of the gas that goes with it?
Do you believe they mix in the same quality as they use for ethanol free gas?
it most certainly is worse.... after all, they only have to end up with an octane rating of 85 or so with the pure gasoline portion, then blend in up to 10% ethanol and now we have an 87 octane rated fuel.
