Here's an update to my chain issue. I got a skateboard wheel and mounted it directly on the motor mount plate. It may seem like it's bending and there's too much slack, but that's because the chain isn't tense yet and I haven't shortened the chain. That'll be today or tomorrow.
After I remove the link from the chain and put the master link in and adjust the wheel to tighten it, I should be almost good to go. Motor is in, chain is on, I'm working on a mount for the controller. Throttle and grips are being installed today. I just need to figure out the battery situation and then wiring.
