Old 12-26-2013, 03:22 PM   #27 (permalink)
Daox
Another month, another update:
1) Using suntuf as the only roofing on a large shop?
Skyking asks about using suntuf corrugated polycarbonate as a roofing
material to aid in heating his shop.
using suntuf as the only roofing on a large shop? - EcoRenovator
2) Internet / wifi thermostats
Daox does research on the available internet / wifi thermostats, and then
goes about installing and reviewing the one he selected.
Research:
Internet / wifi thermostats - EcoRenovator
Install and review:
Motison CyberStat CY1201 WiFi thermostat installation & review - EcoRenovator
3) Cycling Losses for Gas Furnaces
Servicetech brings up the question of how much cycling losses hurt your
energy usage.
Cycling Losses for Gas Furnaces - EcoRenovator
4) Solar hot air panel construction guide
Solarhotairpanels put together a very nice PDF guide on how to build
your own solar hot air panels. He has had great success with his own.
Pics of 2 DIY systems being built / Hot Air Collectors and Drainback System - EcoRenovator
5) Does bubble-wrap work for insulating windows?
AC_Hacker did some testing a while back to see if bubble-wrap works for
insulating windows. Check out his results.
Does bubble-wrap work for insulating windows? - EcoRenovator
