Thread: C-Max diffuser
Old 12-28-2013, 02:57 PM   #9 (permalink)
Recumpence
My C-Max - '13 Ford C-Max SEL
Here are pictures of the finished diffuser. The angle is 10.5 degrees. That is about as shallow as I could go with the layout of the car. That is actually pretty good, though. At first it looked like 14 degrees was the lowest angle I could achieve.
The outer air skirts are just on the inside edge of the tires. I plan on making rear wheel spats that attach to the skirts eventually.
This whole diffuser is relatively light. I have not weighed it, but for how big it is, it sure feels light in the hand.
Next is the under pan. The car has a nice nose pan and various pan inserts under the car to somewhat smooth the airflow. But, it is still far rougher than I would like.
Matt
ID:	14307   Click image for larger version
ID:	14308   Click image for larger version
ID:	14309   Click image for larger version
The Following 3 Users Say Thank You to Recumpence For This Useful Post:
California98Civic (12-28-2013), jeff88 (12-28-2013), woodstock74 (03-22-2014)
