Old 12-28-2013, 08:47 PM   #19 (permalink)
kennybobby
Southern Squidbillie
Have you run it loaded?
Originally Posted by Cobb View Post
I got a harbor freight generator that is rated at 800 watts, runs 5.5 hours on a gallon of fuel. Wow, either its pretty efficient or just a very small displacement?
Probably small displacement because it's not very efficient. The energy content of a gallon of gasoline is 36.6 kWh, and 800 watts for 5.5 hrs is 4.4 kWh, so the efficiency is only about 12%. And i doubt it will run at 800 watts continuously so efficiency will be even less.
