Old 12-28-2013, 10:38 PM   #59 (permalink)
Cobb
Typically its the last cell in a batter towards the negative terminal that is lower than the rest as well as the last battery in a string that has a lower voltage.
Caps go way out of balance more so than anything else and the math you are throwing around is worthless if cap 1 is 100% capacity and the rest are 50% the last 10%.
