Originally Posted by vlad
I would never try this. It is like connecting propane tank to cng station. Something goes wrong you end up with BOOOOOM just like some guys in well known video on YouTube.
Um, not sure why you are fear mongering at this particular point... the pressure is dropped later on in a CNG vehicle anyway, this way you can use a lower pressure (cost) ANG tank, presumably with safety bypass on the fill valve or something so you can do a "quick fill" when you need one, given the limited energy density...
