Thread: 1995 saturn mod
Old 12-30-2013, 05:29 PM   #7 (permalink)
arcosine
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
You put on the wrong transmission, you need a single cam transmission, its geared better. If you want to run it open loop, you can lean it by changing the resistance of the engine tmp sensor, you can put two in parallel and stick one on the head. You can advance the timing by putting diodes on the map sensor. Not as easy to play with as the old distributor engines.
- Tony
