Old 12-30-2013, 11:04 PM   #94 (permalink)
vlad
Originally Posted by P-hack View Post
I know but you are well into "one off" land at 1200psi, so it isn't going to be much use to anyone else, whereas finding an appropriate source of activated charcoal would benefit many.
To build 1200 Psi CNG pump is real. I keep collecting all necessary parts and as soon as I get them all I will start building. My plan is to build a pump capable of pumping to 2000-2500 Psi.
I only use high pressure components rated the lowest of 5000 Psi. 1200 Psi is just a number I need for my daily driving needs.
I don't think 2 GGE is so useless. This is giving you a range of 60 miles using a small fuel efficient vehicle. If my pump can pump 2500 Psi this will give the same range but you can use only 1 tank.
At least I can see this as today reality. ANG....??? I am saying yes I love it but who knows when?
