Old 12-31-2013, 10:52 AM   #8 (permalink)
RobertISaar
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
i like dealing with discrete components myself, due to simplicity/cost, but i wouldn't be opposed to an easy to learn microcontroller either.
that being said, you could run the signal through a diode and drop some voltage. a lot of the more common signal diodes would drop .7 volts, though there may be a suitable diode out there that would drop close to 1 with the current load you would pas through it. that is the only real issue that pops up for me, the voltage drop vs current characteristic.
