Originally Posted by vskid3
When you bump start it, are you just lifting your foot off the clutch or do you lift it enough to the clutch to grab and then press the clutch for a second to let the engine come back to life (using it like the starter works)?
I would let the clutch out smooth and fully engage. Never needed to re-disengage a clutch in the past with other cars. If I get a chance I will try the IACV disconnect today. Winter sucks, cold sucks.
