I hear from the discrete camp a lot, but having invested in micro-controllers I really see them as much simpler in terms of number of components used and cost, as well as flexibility.
A little more advanced, but apparently you can use arduino on an attiny45 (and use the arduino to program it). The wiring might be this simple, and a possible sketch (program), definitely worth looking at microcontrollers since one component can do the job and is like $0.50.
arduino on attiny
Code:
int val = 0;
void setup()
pinMode(0, OUTPUT);
pinMode(3, INPUT);
void loop() {
val=analogRead(3);
//val=val - some constant (bench test for value) for base zero
//val = val * another constant
// to get full scale deflection of meter (bench test again)
analogWrite(0,val);
edit, analogRead returns a value from 0-1023, for 0-5v respectively.
analogWrite takes a value from 0-255 (255=100% duty cycle ~ 5v), so you can probably calculate the needed constants.
