Old 12-31-2013, 01:37 PM   #11 (permalink)
P-hack
P-hack's Avatar
awesomer - '04 Toyota prius
just for fun here is my attempt at a working program, no ownership implied
Code:
int val = 0;
unsigned long time;
boolean overboost;
void setup(){
  pinMode(0, OUTPUT);//don't need to set pin 3 for analogRead
void loop() {
  overboost=false;
  val=analogRead(3);  //
  //val should be between 204 and 716, 1v and 3.5v
  val=val-204;//  val between 0 and 512
  if(val<0) val=0;
  if(val>510){
    val=510;
    overboost=true;
  val=val/10; //val between 0 and 51, just right for 1v pwm
  if(overboost){
    time=millis()%500;
    if(time<250){
      val=0; //turn off pwm for 250ms out of 500ms
             //  so the display flashes indicating overboost condition
  analogWrite(0,val);
Binary sketch size: 1,460 bytes
