i could reasonably approximate my curve correction needed with a 16 or 17 variable table with very little error. i did the check against expected vs reality in .25 volt increments over the 0-5V range, so a 21 variable table would allow me to use my findings directly, but interpolating between the values i have wouldn't be that difficult.
....... i should probably quit threadjacking now.
