Aa thin coating of a low viscosity substance verses thick grease does not show anything new nor groundbreaking. You could show the same thing with a clean bearing and one filled with peanut butter.
so a steam engine spins faster at 0 load, neato
. Now put a working load on it, will it pull a 30% bigger till at the same speed on the same throttle setting, or plow 30% more fields before running dry?
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
