car would just reduce idle air control valve setting and still idle at same RPM. Consumption would likely be about the same though as at idle the engine is mostly overcoming the load of pumping past a throttle plate. For the steam engine though the faster idle does mean more consumption/unit of time to idle, unless the operator throttled back. Still fails to equate idle speed to fuel consumption doing work.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
