Old 01-02-2014, 10:13 AM   #44 (permalink)
kach22i
Originally Posted by JasonG View Post
This time I'm trying some treadmill belt that I acquired.
Seems to be durable but is a pain to work with due to being floppy.
That does look a bit wonky - sorry.
Here is what I did to brace a thicker but more expensive conveyor belt material.
Chin Spolier - fast/easy/cheap/effective - Page 2 - Pelican Parts Technical BBS
The photo above is of the backside, original lawn edging remains intact (along with vinyl cove base lip/splitter). The photo below shows the exterior.
http://forums.pelicanparts.com/off-t...fective-2.html
From post #19 on page-2:
I was planning on using 18ga 2"X2" angle but had trouble locating any.
Instead we used a scrap piece of 3/4" EMT conduit.
Good thing too, the bumper is a continuous radius that would've been very difficult to bend with the angle.
After installing it we found no kickers were needed as it was very stiff from the curve ( as Euromodder said )
Once again pictures had to wait until dark.
Jason, do you have a larger image from the inside showing your lower 3/4" EMT conduit support?
It appears to just dangle, untied to any supporting structure above, and relies on the arc of the curve for deflection strength and deformation resistance.
Is that observation correct?
aerohead (01-02-2014)
