Originally Posted by suspectnumber961
Good luck...fools.....
Seeing as you have decided to issue insults first then I feel able to respond in kind.
You sir are a muppet of the first order.
Big Bird has more credibility.
You are a class A poltroon unable to debate his case openly, unwilling to answer as to the voracity of anything you post, unwilling to respond to open challenge.
You are an onanist with little of any productive substance to offer the world except for the stony ground.
Your wings are beneath my wind.
You are the codpiece of misfortune tied unknowingly around the lower front of destiny and you need to be removed for anything useful to come out.
You are nowt more than a muckworm attempting to deny the citizens of this planet their good health and wealth
You are a sneaksby of ill intention except the ensouragement of the good citizens of Ecomodder to enter into unproductive discourse and disharmony.
You and your information are not worth a dodkin to anyone with a brain, wit and access to Google. (other search engines are available)
When god was handing our critical thinking and independent thought you were busy with Lego and listening to David Suzuki to join the line.
If you demand satisfaction sir, I am ready for your challenge - although I reserve the right to choose weapons, and I choose
sausages.
Otherwise
futue te ipsum for I see no further purpose here.
Regards
A.
