Old 01-03-2014, 06:35 PM   #1 (permalink)
alexander.foti
Mpguino on a carberutted motorbike.
I have recently traded in a 2001 fzs which had an ultragauge installed.
It's a small computer that replaces the fuel gauge and taps into fuel level, rpm, speed pulse etc. It also had a feature that could provide fuel economy readings.
It did this by tapping into the fuel pump. Then pump was a diaphragm type which would pump up, then hit a contact which would turn the pump off again, essentially providing a "click per liter".
It seemed to work pretty well and was fairly accurate.
Each click had a defined amount of fuel flow (my setting was 1778 clicks per liter).
Would the Mpguino work using this fuel pump click instead of an injector pulse?
