MPGuino + FlexFuel device?
Hello!
I installed an FlexFuel device on my car, and then the MPGuino did'nt work anymore.
I understand that the order should go like this:
ECU -- FFV device --MPGuino -- injector.
But it does'nt work. If i keep it like this:
ECU -- MPGuino -- FFV device -- injector.
It appears to work, but as i understand, it shows false reading because it takes what ECU gives, not what actually happens at injector, as the device extends the pulse.
It should work as i installed it, but it just does'nt. The MPGuino is hooked on the minus wire of the injector.
Any suggestions?
