Old 01-04-2014, 05:56 PM   #24 (permalink)
drrbc
Thenorm,
Thank you for the kind compliment.
You have brought up another excellent point- did aardvarcus' misadventure give us more than one "learning opportunity"?
I'm very happy he was kind enough to share his experience, and doubly happy he didn't blow himself up. But what makes me most happy is that it didn't happen to me.
Would it be safe to say 50% or more of the "ecomodding" inspired MPG gains are a result of "adjusting the nut behind the wheel"?
Would it be just as safe to say 40% or more of the "ecomodding" inspired MPG gains are a result of aerodynamic mods? And that the remaining 5-10% are mechanical?
I don't use all of the hyper-miler tricks (not sure all are safe, practical or prudent), but I use enough to return me almost 3 mpg more than I was getting in my monster flying brick supercrew. The CAI/exhaust, and tonneau have given me another 2, maybe 2.5 mpg.
And now I'm considering aeromods devoid of any professional automotive safety engineer input that I will personally and incompetently install myself. Fortunately, I feel it's fairly obvious that things like bondo's Aerocap, and garden edging air dam are pretty safe (unless my home made one flies off at highway speed), at least for me.
How many times have brakes or steering failed in an engine off coast? Have their been any unusual fires or system failures that put life or property at risk related to modding. I know I can save a bit more mpg if I remove all of the weight of the airbags and restraints, but should I?
As I said, I don't find all of the hyper-miler tricks to be that wise (for safety issues). Nor do I necessarily find all of the aero and mechanical mods wise for the same reasons.
With more negative feedback we may find a lot of RoT's waiting to be discovered.
I plan on being more active in this forum in my quest for my personal grail- 25mpg, and I promise I will try to bear in mind always your suggestion "maybe we need a rule of thumb" for the safe promotion of ecomodding, since I suspect there is a whole lot more than a single rule that is needed. We should encourage people to publish more of our failures- especially when "learning opportunities" are present (I personally learn more from the failures anyway).
How about even a "Rule of Thumb's" sticky? Putting our bad outcomes in one place would provide an excellent knowledge base.
I'll even suggest Rule #1:
1. Thenorm/aardvarcus Rule (aka the "Make Sure it Can Cool Off" Rule)- All mods should consider the potential to create conditions where unanticipated heat energy may build up, as well as the potential to impair the convective and radiative dissipation mechanisms engineered in the stock, which may result in catastrophic failure.
What do ya think?
The Following User Says Thank You to drrbc For This Useful Post:
aardvarcus (01-04-2014)
