Old 01-05-2014, 12:38 AM   #96 (permalink)
tvbd56
0.29 Cd and decreasing
Red Rocket - '90 honda CRX HF
Team "Old SKOOL"
90 day: 53.46 mpg (US)
Originally Posted by California98Civic View Post
Thanks! Your autotrans at least has slightly taller gearing than the EX manual, though (IIRC).
And here are a few more tweaks to existing mods. First is the redo of my upper grill block using some aluminum flashing I had laying around from a fireplace project. Then, second, is a series of pics for the wheel well skirts. The only change is the addition to which are two more clips to each skirt to hold them more snugly against the car. I made the clips from small aluminum mint boxes I had saved to reuse for something.
At about 60mph I'm running about 2450-2500RPM, at least that's what my speedo says while my scangauge says 2400RPM.
Do the added side skirts scrape at all with normal driving? I have 6in lawn edging on my front bumper and it scrapes from time to time so I would imagine that edging on the skirts would scrape as well.
