Old 01-05-2014, 12:29 PM   #330 (permalink)
XprizeRoadTrip
Originally Posted by visionary View Post
Update 018
So I’ve just completed the basic prep list before my next test run, and I had a quick spin around the block on the machine to ensure I didn’t waste time and money on a venue hire fee, and hit problems.
Its been almost a year since I last drove it and today’s drive was like a fresh experience. So some aspects of the vehicle were quite a surprise – notably the weight and its effect on ground handling.
By “ground handling” I mean the time when the vehicle is not being moved under its own power. From the seated position, keeping the vehicle upright is no problem but it needs a parking brake since the force vector from the supporting leg tends to push the machine backwards.
The vehicle feels much heavier than I remember and it is extremely awkward to manhandle without a helper. This would be remedied by fitting a easily deployable stand and some handles or body features that enable easy holding, the smooth bodywork gives you nothing to work with.
Anyway, since I’ve been adding weight with everything that I’ve made, I thought it wise to check what it is now. So here’s a photo of the vehicle on cornerweight scales.
The results are –
Total weight (empty vehicle) : 205kg Front wheel : 85 Rear wheel :120
Total weight (me seated inside):274kg Front wheel :112 Rear wheel: 162
So it’s put on some weight and needs a diet. I’ve been making things in steel, for speed and simplicity and I knew things were heavier than ideal but it was still a shock to be over my target at this stage.
It's good to see people like Visionary actually doing this, building from scratch and learning the design challenges involved in the delicate balance between weight, strength, performance, efficiency and safety. When I saw Edison2's Xprize car, it was a powerful example of designing for that balance on the front end as much as possible and minimizing compromises from there out. As Ron Mathis said,
There are only two absolute virtues for an efficient car: the first is light weight and the second is low aerodynamic drag…everything else is a desperate compromise.
Edison2 has taken heat from Ecomodders because their vehicle isn't available yet as a kit or production model. But in terms of learning how to this from scratch, they're a great example of how dedication to physics and best practices creates desirable results. In my opinion, I believe the Very Light Car will be come a kit car in one form or another sooner vs. later. Ron Mathis drew the vehicle such it could be easily mass produced or assembled as a kit, and I've spoken with him a number of times. Few may know this, but he really believes in the VLC as a kit for several reasons; it makes too much sense not to do it.
FYI for those who haven't seen, here's where the Xprize Very Light Car ended up for specs, from this page: Edison2 - X Prize VLC
Dimensions & Weight
Overall Length 167"
Overall Width 79"
Height 53"
Wheelbase 100"
Front Track 70"
Rear Track 70"
Curb Weight 830 lbs
Engine Placement Rear Engine
Luggage Capacity Up to 22 cu-ft
Standard Seating 4 Passengers
Engine
Type 1 Cylinder, DOHC, Turbocharged
Displacement 250 cc
Max Power 40 hp
Max Torque 29 ft-lbs
Fuel E-85
Control Strategy Extensive Exhaust Gas Recirculation
Drivetrain
Type Rear-Wheel with Differential
Transmission Manual Sequential, Auto Clutch Option
Number of Gears 6 + Reverse
Features Full Neutral Disconnect
Hybrid Option Electric Drive / Power Take Off Capable
Chassis & Suspension
Chassis Steel Tube Frame w/ stressed skin
Steering Rack and Pinion
Turning Radius 18'
Front Suspension Type Edison2 Proprietary Design
Rear Suspension Type Trailing-Arm with New Force Mgmt
Front/Rear Shocks Adjustable Gas-Pressurized
Front/Rear Springs Coil
Brakes 4-Wheel Water Jet Cut Disc
Anti-lock Brakes Capable
Stability Control Capable
Fuel Capacity 6.5 Gallons
Performance
Fuel Mileage 129 MPGe (highway) 110 (combined) in on-track testing at the X Prize
0-60 mph 14.2 seconds
Top Speed > 100 mph
Range > 600 miles
Interior
Heat Heating System with Defrost Function
Air Conditioning Conductive Cooling
Windshield Wiper 3 Speed with Intermittent Function
Audio System Ipod Dock Sound System
