Originally Posted by computerpc101
I have an old 89 Civic Wagon 5 sp, I would like to modify it and run it slightly lean. I have 3 pin PA sensor, One end/centre pin measure about 3K, other end/centre pin measure about 5K, Would you tell me more about how that how I connect those potentiometer?
Thanks
All I know to tell you is that one of the wires is 12v one of the other wires is somewhere around 2.75-3v. You want the lower voltage one. The other wire is the ground. You will have to use a volt meter to check them out. Remember to turn the key on or you may be scratching your head for awhile.
