Old 01-06-2014, 02:24 PM   #8 (permalink)
XYZ
Originally Posted by Mudgey View Post
I don't think dirt is a problem, if anything it will keep the engine clean, this is a good thing as the car is going to be shown at car shows this year I can whip it off and not have to clean as much as I would have too!
The blanket will keep the engine clean, but the blanket itself will get dirty over time - which might be a chore if you need to remove it.
How hot the engine gets should be goverend by the t-stat, how hot everything within the insulation gets is down to testing! Things such as the TB, alternator, supercharger, exhaust manifold etc will be outside of the engine blanket.
Also consider installing a higher temp thermostat, if there is one that will fit your car.
I could never run it cold! its needed to demist the windscreen and keep me warm, I have to have some creature comforts!!
For comfort, buy an add-on seat warmer that plugs into the lighter socket. They are inexpensive and they work well. It will keep your butt happy while waiting for the heater to produce heat.
