Old 01-06-2014, 04:35 PM   #41 (permalink)
gone-ot
...beats walking...
MetroMPG -- agreed! HCCI is 100%-time lean-burn, but with diesel-like efficiencies due to high CR and high in-cylinder temps (ala' diesel). The problem (so far) has been maintaining drivability across the whole idle-to-high-rpm range, which (so far) has been only partially compensated by reverting to spark-plug ignition at partthrottle speeds where the very-lean AF mixture makes sparkplugs almost useless.
The Following User Says Thank You to gone-ot For This Useful Post:
RustyLugNut (01-06-2014)
