I found the problem.
The flexfuel box was not giving enough current to the injector(mono point), so i modified it by paralleling the inputs and outputs.
And when that was solved, the MPGuino got a proper signal.
I always thought that the injector is the most common type, but it's not.
It's low impedance, but still normal, not peak-and-hold.
