Originally Posted by CFECO
97 Jeep Cherokee, I had the angle grinder with metal cutoff blade ready, and the carpet rolled up, then I replaced the fuel pump relay..LOL!
Haha!! If you were in the rust belt you would leave the carpet up and use the same tools to fix the rusted out floors!
Edit: or maybe there would already be a hole rusted out abovete fuel pump. Problem solved
