Old 01-07-2014, 07:27 PM   #21 (permalink)
user removed
Originally Posted by slownugly View Post
intake manifold in a 96 altima 4 cyl. called for 6 hours. ive never been so mad at a car in my life. id rather pull the engine next time.
If you think that was bad try replacing the seal between the block and the front timing chain cover. Early Altimas were notorious for leakage from that seal. Do you pull the head (after pulling the engine) or try to reseal the portion of the head gasket that is exposed when the front cover is removed?
regards
Mech
