So you are increasing auto stop so to speak and using what heat is available in the cooling system? The Insight you can easily run out of heat in auto stop and when at idle you can watch the temp noise dive to 130 degrees with the heater on. I tend to drive more aggressively in colder weather til the cold is worn off inside the car, so short trips just do not have good mpg.
