Old 01-07-2014, 10:51 PM   #15 (permalink)
oil pan 4
Do you have an evalbum page or can you list all the parts you used? Looks like you went with high quality stuff, with the zilla and a warp 9 with trojan batteries. What else is under the hood (or bed)?
Originally Posted by MPGsteward View Post
Not much else to list: Iota dc/dc converter, energizer 12v deep cycle battery for accessories, canadian ev adapter plate on original manual transmission, manzanita pf 20 charger, 18 trojan flooded wet cell 6volt deep cycle golf cart batteries ran in series, 0/0 copper welding wire connecting batteries, helper springs, coil over shock absorber in rear (sensatrac).
Going with top notch components will add reliability to your EV conversion. This truck has been super reliable.
I use to have the batteries in the bed. welded up some battery cages underneath and the truck now handles better. the center of gravity was improved.
That sounds a lot like how I would do it.
