apologies up front for not reading all dozen pages so this may have been covered.
I love the idea but don't think you will make it work. First thing that crossed my mind was when you said "My car can apparently generate 115 hp with the 4 cylinder so it would make sense that a 2 cylinder would give 57 hp" With two cyls disabled you would actually make a fair bit less than half the hp because of the other losses of mass, friction, etc.
Best bet I can think of would be to run a cut out switch to the injectors of either 1 & 4 or 2 & 3 and simply flip the switch to shut off fuel to two cylinders once you are up to speed. You could get creative and have two get automatically shut off over a certain rpm if you can do the electronics. You might get a half scale savings in fuel consumption of what you get while under dfco if done this way. Easy enough to try. Love to hear the results.
Get bored very quickly. Vibe, Saturn, and crv all long gone. Been a while but I'm back in the game, gunna see what I can do with this Corolla.
