Old 01-10-2014, 02:16 PM   #109 (permalink)
Frank Lee
Originally Posted by Really really bad idea A
Best bet I can think of would be to run a cut out switch to the injectors of either 1 & 4 or 2 & 3 and simply flip the switch to shut off fuel to two cylinders once you are up to speed. You could get creative and have two get automatically shut off over a certain rpm if you can do the electronics. You might get a half scale savings in fuel consumption of what you get while under dfco if done this way. Easy enough to try. Love to hear the results
Originally Posted by Really really bad idea B
...and hold the exhaust valve open a little to kill the compression and vacuum cycles, it should easily still make 20 HP.
