Old 01-11-2014, 10:09 AM   #1233 (permalink)
Arragonis
The PRC.
Originally Posted by NachtRitter View Post
Since no one was able to answer this question, I did a little research myself.... Thank you, me.
I added thanks to your previous posting just now, top research - I went away due to the return to work after Christmas, or rather Hogmanay as it was at the time.
What are your thoughts on the differences between the climate models and observations. For example the Met office here has reduced it's predictions of temp rises due to CO2 as they have newer models.
If the models are too hot (and apart from some resetting of the base years to try and argue the opposite they are) then should "policy" be influenced by them?
