When you fill up the car, you tell the SG2 that you filled and it will ask how many gallons you added and price, just keep adjusting till it matches. Try to fill at the same pump while doing it and fill it the same way, 1 click, 2 clicks. After 3-4 tanks it should be good.
Use the same fuel each time, it doesn't adjust for E0, 10 or 15. It uses airflow to calculate fuel, with higher E blends the engine needs more fuel to the same air so it won't calcuate correctly.
