Originally Posted by smokey442
Simply form a good data base with your existing configuration. The larger the # of samples the more accurate results. Compare that to your post modification results. Don't waste time going back to A when you already know what A is.
Not going back to A leaves the opportunity to miss things. I am not trying to argue, I just want to make sure it's clear that information can be missed by not going back.
