I think idle for an Auto in N is fine from what I have read here and elsewhere as the engine also pumps transmission oil.
Engine off is a different story as the trans is not lubed. Check the towing instructions. If they say limited speed / distance then you shouldn't coast with the engine off.
I also shift to N on lights, and shut off at standstill on long lights (shift to P).
