Old 01-15-2014, 01:06 PM   #16 (permalink)
kach22i
Originally Posted by chefdave View Post
on aero mods im i better to put front air dam as close to ground as possiable. ............like the idea of the pick up cab rear wing that would be easy to install.
Dave I believe the prevailing wisdom on chin spoilers is that they need not be any lower than the lowest thing underneath, such as your rear differential. On my own pick up truck, that is about 7-inches from the ground, although I haven't measured it.
On the second topic, some sort of treatment/garnish at the rear top edge may do something for you. I would not expect too much though, the scale of the project is just so overwhelming at first glance. Might be best to nibble around the edges before biting off too much.
http://ecomodder.com/forum/showthrea...1-a-19525.html
EDIT 11/21/11: This is pretty close to what I am first testing. Tonight I get to do some serious highway driving, will be doing more driving tomorrow as well (I work from home).
The Recumbent Bicycle and Human Powered Vehicle Information Center
Additional mods for Vans and SUVs::
A new spoiler design has been shown to reduce drag and lift significantly on bluff-backed vehicles such as minivans and SUVs. Simulations showed that aerodynamic drag on a mini-van moving at 67 mph were reduced by 5% when the new spoiler was attached. This rear spoiler acts like a diffuser when it is attached to the back of a vehicle, making the pressure on the back of the vehicle higher than without it. That's a good thing!
Full technical paper ($22)
A Rear Spoiler of a New Type that Reduces the Aerodynamic Forces on a Mini-Van
NOTE: Last night I added plastic automotive button head plugs to the open holes on the trailing wing edge. I snipped and did some grinding to make it flush on the bottom (they were too long). I used a butane torch lighter to soften the plastic plugs before inserting, as they were a bit tight and got stuck half way in a test fitting.
http://ecomodder.com/forum/showthrea...a-19525-6.html
I took pictures of the Scion IQ yesterday because I noticed the roof spoiler is actually a 45 degree wedge which slides air flow though a slot - similar to my own roof device.
Aerodynamics Photos by kach22i | Photobucket
renault_megane_dci (02-01-2014)
