Does your temp gauge go up to the middle after about 3 miles?
Check your cam shaft timing, there is a 2nd set of timing marks on the head that the upper pulley needs to line up with instead of lining up with the top of the head.
You might also make sure someone didn't put gear oil in the transmission, it's supposed to have 10WW30 motor oil, very thin compared to gear oil.
