Old 01-16-2014, 04:52 PM   #9 (permalink)
Jack-Lee
Jack-Lee's Avatar
Partygurke - '90 VW Polo 2F
Rodi - '04 Smart Roadster Coupe
Hi,
Cam Datas:
CAM from a Polo 6N with ABU Engine
111.5° ATDC
Duration @ 1mm 211/215
Max Lobe Lift 9.4/9.6
hydro"stößel"
Valves:
Standard from "G40" (exhaustvalve with natrium)
Intake Valve:36mm (Port 30,5mm)
Exhaust Valve:29mm (Port 26,8mm)
Valves polised and the ports are aerodynamik tuned
Intake Manifold:
Length 300 (standard about 130)
Runner Dia: 30,5mm
Made of Alu or CFK, im not sure what material i use.
Exhaust "Fächerkrümmer" 4:2:1
Section 1 (from each cylinder): 32mm (the "step" from head to exhaust minimized the reflow in the cylinder)
Section 2: (for 2 cylinder) 45mm
Section 3. (for all) 50mm
@rusty lug: What numbers you mean?
