Old 01-16-2014, 07:52 PM   #8 (permalink)
nwrubicon
Alright so I'm a lube tech at a gmc dealer and I had out shop foreman look at it. Fpr isn't leaking, and Now that I think about it the distributor is almost all the way retarded to set it at the 16 degree mark so my cam timing might be off being that the distributor shouldn't have to be maxed out to achieve a factory timing. I will check the cam timing when I get home along with the o2 sensor
