Old 01-16-2014, 06:58 PM   #9 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by jedi_sol View Post
Tools: Torque pro app, used a graph to measure speed (y axis) vs time (x) axis. Then after each run, I used the graph to see how many seconds it takes to go from 40-20.Very useful!
From my experience, phone/car type GPS isn't accurate enough to pick up small gains. If you watch your GPS speed it will often jump 5km/h at a time. Even in gentle coast down tests 3km/h jumps are typical.
I have a bicycle Garmin unit that will log and stamp at selected intervals down to 0.1km/h. I've used it before in AutoX because I can actually see my lines through corners with it along with terminal and apex speeds. Only now do I realize it would be a great way to do both real world and coast down tests.
I did my first coast down testing last week just to play with the method, I used the Scangauge numbers because it was easiest (these also jump at 3km/h intervals in coast down testing). To my surprise, when I ran the numbers my calculated cd matched the factory figure (although my bigger tyres should have made it worse).
I also tried mirrors folded and could find no difference (these are big mirrors too). It's worth noting that some cars like the Ford Falcon AU were reported to have a lower CD with mirrors than without. The mirrors were designed to help deflect air away from the B pillars. I imagine this is the case on 90% of new cars.
